I got a 12v socket and new fuse. I even got a voltmeter and checked both fuses under the hood and by the driver side doorDo you get 12v at the socket? What about at the fuse? Replace the fuse with a fresh one just in case. Sometimes they get finnicky as they age.
Were you able to measure 12vdc AT the socket? If you have 12vdc at the fuse and not at the socket, you have a short between the fuse and the socket in the wire harness.I got a 12v socket
Ok so what will I have to do then?Were you able to measure 12vdc AT the socket? If you have 12vdc at the fuse and not at the socket, you have a short between the fuse and the socket in the wire harness.
did you use the cigarette lighter of the push in , then it does not burn the pot ... a lot of the older lighter flame heater ..03 silverado cigarette lighter not working. I checked all fuses, pulled console and checked wiring and changed socket. And still nothing any suggestions
First confirm that you are getting 12v at the fuse and not at the socket. If you have a short in the wire and it is not blowing the fuse it might just be a break in the wire (not touching a ground). You have to find it and repair the break or just run a new wire feom the fuse to the socket.
It was runningSome trucks need the key on
I added more info to that postIt was running
Yes I checked both sidesI added more info to that post
