1 - 6 of 6 Posts
Hi there, I have a 2003 Envoy SLE, 4x4, 4.2L
#1 - I was reading on a previous post about people having a clogged throttle body and how I can clean it myself for about $15 and 45 minutes of time...can anyone direct me to a site on how to do this, or give me directions on this? Thanks...
#2 - When I engage my 4x4 and i turn the steering wheel either way while driving I get a "clunking" sound happening. It seemed to only happen when i was backing up, but now it looks like it happens while in drive as well...I hardly ever need to use my 4x4, but i am worried this might be a BIG problem and would like to know if anyone else has had this happen.
Thanks for your help!
DC
Super Moderator
#2: Under what road conditions did you have it in 4H? On dry pavement (or whenever traction is good), the drivetrain is going to complain in 4H. This is because the front and rear are locked together so they can't spin at different speeds. But, when turning, the front needs to spin faster than the rear. Under low traction conditions, the tires can slip easily to relieve the tension. If the tires can't readily slip, then you get hopping, groaning, clunking, and breaking.
Completely agree with that. I was headed into a hay field a few months back to do some fence repairs and accidentally, stupidly put the truck in 4h as I was turning into the field from dry pavement.
If this continues to happen in slippery conditions I would have it checked out. It could be a bad CV joint.
It is hard to tell if they are bad unless they have a ripped boot. But that noise/clunk you speak of is one of the symptoms of a CV joint that is on its way out. Only if it does it in slippery conditions.
I am a CV joint connousieur. I've broken both of the CVs on my suburban over the course of 2 weeks. You will notice a clunking when turning and occasionally a twitch in the wheel. When you put it in 4x4 it usually gets worse.
Discussion Starter · #6 ·
Tyanks a lot, I'll check into it...do you know of any good online stores with lower cost CV joints?
1 - 6 of 6 Posts
