I was installing the rough country 2" leveling kit and I loosened the upper control arm/ball joint bolt and thats where I went wrong. I just loosened the nut and not fully removing it then I hammered the side to pop out the bolt. I realized I needed fully remove nut to give room to put in the leveling kit. but as I try and loosen or even tighten the nut the whole thing spins with the nut. I noticed there was a alan key hole underneath so I put an alan key in and tried again to loosen it but it just ended up sliting the hole apart basically. So what I am asking is, what can I do to fix this problem? I am figuring I have to replace the whole control arm or could I replace the ball joint. Please let me know, I am just a rookie learning from his mistakes haha
Thank you
Thank you
