So when i was aligning the headlights on my 1997 C1500 last night I discovered a new issue. The DRLs and headlights are the same level of brightness. I can't say for certain but I'm guessing that the headlights are the DRL brightness. They don't look all that bright but I guess it could be the other way around; I'm not certain how to even check which light output is correct.
Anyone have any idea where I should even start looking for the problem? I just replaced both headlight housings because the original ones were weathered and didn't allow the headlights to throw much light. Obviously I think this issue may have made it even worse, but I'm fairly certain that this problem existed before I switched housings. The headlight switch itself is working properly, it will turn on the marker lights in the middle position and brings the sidelights on when put into headlight position.
