My 1998 2wd 1500 Suburban has DRL(bought it 3 weeks ago).They are fine for safety, but I want to disconnect them so I can install true HID bulbs in the low beams(9006). The DRL system runs on lower power than "normal" lights,so I don't think it can work with the DRL.
Do all 1998 Suburbans have DRL?
How can I disable them-disconnect them?
I can use the high beams-9005-for the HID, but I would rather use the low beams.If forced to use the high beams,I just tilt them downward like low beams.
Thanks,
Charlie
PS-How i the world do I get access to the 9005's-high beam bulbs.It is behind a shroud of some sort-big PITB. The low beam bulbs are easy to get to.
Thanks,
Charlie
