The fuse for the power outlets is different than the cig lighter. Technically, the other power ports are called the "front auxillary" & "console auxillary" power outlets.
(for the benefit of others) You can find the fuses in the rear fuse block, which is located underneath the drivers-side rear seat. (Just lift the seat up and you'll see it). The fuse for the front & console auxillary power outlets is AUX PWR 1, fuse #46 - 20 amps.
