1 - 7 of 7 Posts
I got around to changing out the ugly magnetic XM antenna for the OEM XM antenna today on my 2008 GMC Sierra.
Rather than trying to extend the OEM antenna wire, I relocated my Pioneer XM brain to behind the top glove box. There is not much room - I put the brain in the slot behind the top glove box, which looks like is a space above the fan motor perhaps.
You will need:
1. Torx head screw driver
2. Wire snips or something that you can trim the plastic around the OEM antenna connection.
You will want to remove the top glove box. Open tnhe glove box and there are 2 torx screws - one on each sides at the top. You can then pull the entire glove box out - the bottom is help by 3 panel clips - these will pop out by pulling firmly on the glove box.
If your not going to be moving your XM brain you can skip this part.
Next I opened the lower glove box - there is a tab on the top that prevents the glove box from opening all the way to where it dumps everything on the floor! Push up on that tab and the glove box will open forward - if you dont clean out the glove box everything will be on the floor at this point!
You will see the OEM XM brain:
Cable management Electrical wiring Wire Electrical supply Cable
The brown plug is the antenna - you may have to trim the plastic to get it to fit your XM brain.
Bumper Vehicle door Automotive exterior Auto part Vehicle
Text Light Font Material property Silver
It looked almost as if OEM connector would have plugged right into the Pioneer XM brain bu t it seems like the shop that installed it trimmed the plastic on the Pioneer unit to accommodate the stupid connector for the magnetic roof antenna! Wait til I talk to those guys next time I see them!
Technology Electronic device Cable Electronics
Here is a shot where I put the brain. You can get some more length on the OEM antenna wire by clipping the wire tie that holds it down to the plastic mount the OEM brain sits in.
Automotive exterior Bumper Auto part Vehicle Car
Hope this helps if anyone is thinking of doing this.
very nice mod
sstoner can you clear a few things for me? Do you have an after market head unit installed? Is the factory xm unit compatible with any of the after market units? I would like to install a new indash nav radio but want to keep my xm. any help or advice would be great.
Discussion Starter · #4 ·
The factory XM unit will not work with an aftermarket head unit due to the configuration of the wire harness that connects to it. Someone would need to develop an adapter much like you would use to connect your aftermarket head unit to the factory radio harness.
Electronics Technology Electronic device Computer hardware Electronic component
I have a Pioneer head unit along with the Pioneer XM brain.
If anyone needs the factory XM for their factory XM ready head unit I have one now!
Thank you.
Awesome tutorial!!!
I was doing the same exact install and got to the part of having to have an extension due to the factory length..
And just by pulling the wires from the position they were on the factory XM box I was able to connect and have just enough length.
1 - 7 of 7 Posts
