needed stuff
- 4 5mm LED's (
http://www.oznium.com/led )
- 3 or 4 feet of wire
- electric drill and bits
and epoxy or silicone rubber
1. remove your grille. and locate turn signal wires
2. take the drill and appropriate size bit. and put one hole in each headlight chamber (4 holes in total)
3. insert one led in each hole and glue in using the silicone rubber or epoxy
4. run the positive and negative the the right wires, you might have to play around with the combination to get the effect that you want. but the black will be the negative
5. splice then together (led wires and turn signals)
6 and then put your grille back on and step back at your new glow.
