:? Any one having a problem with the door wetherstrippings coming off all the time? They are not glued on or anything, and they keep popping off when I shut the doors. Mostly the back two doors.
The only problem that I had was the seal/stripping that went around the rear license plate holder. That seal went bad and had to be replaced. I had the dealer fix it under warranty and all is good.
You could always get some clear RTV from an AutoZone and use it to glue them. I noticed the strip over the rear drivers wheel starting to sag a little. I just pushed it back in place.
A forum community dedicated to all General Motors truck owners and enthusiasts. Come join the discussion about performance, lift kits, wheels, tires, modifications, troubleshooting, maintenance, and more!
