1 - 4 of 4 Posts
i was wondering if a flip kit and drop hangars would work in the rear end of my pick up? also what would i have to do to make it level out in the front? i have a 2001 gmc sierra.
You will have to implement a c notch in your frame. This will consist of cutting your frame and either making a c notch yourself, or buying a kit. Either way your towing capacity will surely change. Depending on how low you want, you will need to specifically get the right kit. From my understanding a flip kit will automatically drop the rear 6", and 4" is the max you can drop without a c notch. Not sure if this helps, but my 2 cents.
1 - 4 of 4 Posts
