I have a 2002 Chevy Suburban 1500 4x4. I have been experiencing some sporadic electrical issues when starting my truck in the morning. It started last fall (2012) after work. I got into my truck and turned the key to start it. When I turned the key my gauges went crazy and stuck in a position, had no power to the dash, and the engine did not crank over at all. After I turn the key again it started. Later that day I was @ a hardware store with my wife. When we were leaving it did the same thing. This time I popped the hood to take a look at the fuses and found nothing. After I closed the hood, my wife said my gauges all jumped. I went to start it and it ran fine. I called my wife's uncle who is a mechanic and was suggested I check the battery connections to make sure they were tight. Which I did. It would do it a few more times then go away for several months. Now it has reared it's ugly head again. Now when it happened recently (this morning) I turn the key and got nothing. My gauges goto a quarter (fuel gauge) and stop. I open my door and close it, put the key in the ignition and my gauges bounce. Still nothing. Pop the hood close it and the truck runs rough and stops. Turn the key again and it runs like a champ and it will run fine for the rest of the day. I did have it in the shop a few weeks ago where they tried resetting the key memory 3 times to no avail. I was told to try this again or try using my spare key which I will be doing next. I don't know it I'm having a ground issue or an ignition module issue. Could use some help with this. It's pissing me off to say the least.
