hello all
1988 350 in a suburban
at idle it has... not a miss... but it almost feels like a miss/ sputter while idling IN GEAR only
like a valve is sticking
which i think is most likely
i was thinking just marvel mystery oil the motor or maybe even ATF it a bit and go from there.
these valve seals and guides are notorious for failing, because oil pressure DROPS at idle. so you need to run thick 20w50 ****.
thoughts?
anyone else have this issue? what cured it for you?
thanks!!
Check your fuel pressure. Marvel Mystery wouldn't hurt it.
Well, as I said in your other thread, I think 20w50 is too thick, if you feel it's necessary to up the weight, try the 5w40, or the 10w40.
Discussion Starter · #4 ·
i once had a stick shift i SWAPPED to a 700r4 automatic.... it would do the same thing and even die somethimes.... i think the 700r4 is just junky like that
the fuel psi was not a issue
it would just put lug on the motor while idleing
