1 - 4 of 4 Posts
Last fall I asked if anyone had an evap code problem w/ a 01 tahoe 5.3L. the saga continues! The only thing different is that it is now cold & the code stays off if I leave the truck outside. If I bring it in the garage overnight (45*) the next am it will code po446 again & doesn't go out. I have replaced the fuel cap w/ gm cap per vin#. and the sol. vent valve.
any ideas/ experience???????????? ( this has been going on for over a year & it also has been evap fogged with "I can't find a problem - that'll be 160 bucks")
this system will usually not run in the cold weather so that is why when you park in the garage it will set the code i looked it up and there is a revised vent valve which you said you replaced it also said to check for a restricted fuel tank vapor line or the fuel tank presure sensor could be bad i have also seen a hose ran from the valve depending on what kind up to the top of tranny so that it dont pick up dust.
1 - 4 of 4 Posts
