1 - 3 of 3 Posts
Hi, new to the forum here. When I turn the van off the starter engages for a bit then stops. Would this problem be the solenoid?
Thanks
No, I'm going to suspect the ignition switch.
Perhaps when you turn the switch to off there is enough wear to somehow activate the crank circuit.
The switch is not at the key cylinder, it's near the bottom of the column.
Discussion Starter #3
Thanks Ray
1 - 3 of 3 Posts
