1 - 15 of 15 Posts
The factory alarm on my 2004 Suburban seems to be messed up. The doors automatically lock when I start the car and try to lock again when I put the car into gear. The doors unlock when I put the car into park. Anyone know what might cause this?
Thanks
Chuck your settings from your steering wheel , you may have to reprogem the controls again . Mark
I just found a switch and a small button under the dashboard. It looks like a cut of switch but doesn't seem to do anything. Any idea what these might do?
Thanks
:confused: :confused: :confused: where is the switch at ? Driver side or poss. side ??? You can at pep boys for a manual like book , or order one throw the dealer. :great:
Thanks
Ain’t it supposed to do that?
I mean except for the trying to unlock.
Sign on here and you can order a new manual for it.
https://www.mygmlink.com/main/US/en/gm/home?cmp=gmcomhp
Locks
I think the doors should lock when the truck is put into gear. It locks as soon as I start the truck and then tries to relock the doors, which are already locked from start up, when I put the truck in gear. Is there any possibility the switch under the dash is a valet switch or something like that?
If you look at the right side of the link I posted you can download a free Digital owner's manual.
There you go.
Discussion Starter · #11 ·
After Market Alarm
The dealer called me and said the alarm is after market. I guess the previous owner installed it. They ssaid they fixed the problem. The car and the alarm were operating the locks independenly and the alarm had to be reprogramed. Thanks
On your steering wheel you have some control buttons. There is a control to have all or drivers side doors lock/unlock either at a certain speed/put in gear/key turned off-and so on, There are many ways to customize the way you like it. This is also true for the lights,mirrors,and some other doamahickies.
My steering wheel has no controls on it.
Consider yourself lucky, the more crap in the wheel the more problems that can happen with it, I loved the cc in the wheel of my old Lincolns but when they have problems they can be a nightmare and expensive.
Hope the dealer doesn’t hose you to bad on the fix.
X2, I work on a lot of Tacoma's, they have a spiral cable running up the steering column that runs all the steering wheel mounted buttons, it'll break if messed with.
I've replaced 6 for friends so far and it isnt my favorite job. You have to remove and disassemble the steering column, cant use a salvage yard part because they break when being removed, the new part cost $145 (at dealer cost) and it takes 6 hours to do the whole job.
I'm sure the GM ones are just as complicated.
1 - 15 of 15 Posts
