has anyone here had problems with getting the old rotors off i have a 94 chevy surb 3/4 ton deisel and every store i go into and talk about these rotors no one has them. they say they are the ones but i know they are not the ones?
On 2wd models, the disc is part of the hub. With 4wd, the disc can be removed when the wheel and caliper have been removed. The exception is the one ton which has the disc pressed onto the hub and bearing casting. The disc must be pressed off.
i had a feeling that i had to press off the rotor from the hub i just wasnt sure i cant complain i have gotten 116.453 miles off the rotors, do you think it would be easer to undo the ball joints to get to the rear bolts holding on the hub and bearing housing or just trying to brake the 4 bolts while its on the truck?
A forum community dedicated to all General Motors truck owners and enthusiasts. Come join the discussion about performance, lift kits, wheels, tires, modifications, troubleshooting, maintenance, and more!
