98 Sierra RWD, 5.7
the truck wont start immediately, if i prime the pump by turning the key on n off like 15 times it will start on the 2nd try and run strong. it will continue to start and run fine as long as it dosent sit for a few hours. Im assuming with these symptoms and lack of codes and since the truck runs perfectly that the fuel pressure regulator is screwed.
Now I have watched the video below from 1a auto... its a great start to finish video except they dont actually replace it with a new one. The recommend replacing the upper intake gasket as a part of the process... of course, good idea. they didnt really clean anything besides the upper intake gasket surface.
I havent been inside a 350 since i was in high school... when I completely rebuilt one of these engines with a team of my classmates. It was a vortec and brand spanking new... it ran great! hahah anyways I dont really have much experience with the fuel system.
SOOOOO my question(s)...
Can any part of the vacume system cause a fpr problem? I see there is a vacume line running to it... I have some sort of leak on top of the motor... its been bandaided back together and I havent even looked into it.... it dosent seem to cause any problems besides a hiss... Ill take a pic of this line in a bit... I dont think its a vacume line.
what else should be done during this procedure.... Im thinking shave the butterfly valve, clean clean clean whatever may be under the intake. how can this be done properly and with what? Im debating on starting this today but probably wont... waiting for some feed back. HAHA
have a goodd one and Thanks Guys!
Al
Al
