Howdy all -
My '86 (350) was leaking some oil pretty good so I figured I'd go after the timing chain cover and replace the gasket. Course that entails removing the water pump too. Got everything cleaned up, but I was wondering how I should go about putting it back together...
Should I just use the gaskets that come with it or just a gasket maker or both? If gasket maker, what do ya'll recommend for both the water pump and timing chain cover?
It looks like I used both when I put it together a few years ago. I used a red sealer last time. Don't know exactly where the oil leak was from, but I do know it was somewhere around the timing cover. Should've bought a new one back then, but...
Thanks for the advice!
Troy
Troy
