1 - 16 of 16 Posts
I ordered a Gibson dual extreme exhaust a couple of days ago and im pretty anxious to put it on my 2011 silverado. I got it out and looked at the instructions and im thinkin it might be best to pay a professional to put it on lol. I heard Gibsons are pretty easy to put on yourself cause they are just all clip on connections but what im worried about is the stock exhaust like cutting it and all that good stuff. I know a couple of yall have Gibson exhausts on here so any advice you can give me on the best way to put this puppy on? or just recommend takin it to a pro?
Ill post picks of before and after once i figure out what im goin to do about the installation. Thanks alot guys!
I assume its a cat-back. If you don't want to save the old exhaust just cut it of with a tubing cutter, sawsaw or hacksaw. Spray the old flange up near the cats and remove it. Its really not hard to do, just take your time and don't get upset.:grrrrrr:
---------- Post added at 05:45 PM ---------- Previous post was at 05:41 PM ----------
Also READ THE DIRECTIONS TWICE. Lay the kit out on the ground next to the truck like it would be mounted and just look at it. You can do it and then buy something else for your truck with the money you saved!!:great:
Christmas in July Mike? X2 on doing it yourself. Save a bunch of money & it's not that difficult.
Discussion Starter #4
haha exactly, the only question i had from lookin over the instructions is how far back from the muffler do you cut? they just say to cut behind the muffler. is that to just take the entire back half off?
They probably don't specify an exact measurement on where to cut in the directions because even identical trucks can be different by an inch or so. I would just carefully measure the new one & then transfer the measurement to your old one before you cut.
Allow enough room to use a band clamp if you ever want (or need) to put the stock system back on.
Mine is an '05 Crew Cab but there shouldn't be that much difference. You have to cut the old exhaust at a point that will allow you to remove it. Once the stock system is unbolted it has to be cut because you won't be able to pull it out over the axle. Before you do any cutting make sure you can get the old head pipe unbolted, if you soak the bolts with WD40 or PB Blaster they shouldn't be a problem, especially since your truck is not that old. Once the headpipe is unbolted you can pull the system free from the rubber grommets and then you should be able to tell where to make the cut, on my truck it was just in front of the rear axle and behind the muffler. After you get the old system out, you can start loosely installing the new system. Start by bolting the new head pipe up, it should only fit one way, and then you should be able to figure out which pipe goes on which side from the instructions. If I remember right the instructions aren't too awful bad. Just fit everything loosely until you get it where you want it and then tighten everything down. I know it can be a little nerve wracking to take a sawzall to a perfectly good exhaust, but take your time and take a deep breath and start hacking away! I've had 2 Gibson systems now and both installs went without a hitch, and had them both done in around an hour.
Keep us updated, looking forward to hearing more.
:great::great::great::great::great:
Discussion Starter #9
oh cool that just helped me out alot thanks guys! ill hopefully get it done today. i think once i make my first cut it will be easier but im a little nervous about it lol thanks again guys and ill keep you posted
Discussion Starter #10
so after 6 hours in 200 degree weather the exhaust is finally on. She growls now and i love it! the installation was really easy but taking off the stock exhaust was the hardest. I went at it with a hacksaw and it took me a good hour and a half to hack through that cause theres no room to put a saw down there, but after hitting my knuckles and a few bad words it finally came off. I was so surprised by how easily the Gibson went on. The only thing i think im going to have done to it is have all the connections welded, especially the chrome tips cause they would be pretty easy to steal and just in case theres a leak i didnt hear. props to gibson for making such a good exhaust and an easy instal! i absolutely love it! i would recommend to any one i know
oh and thanks for all the help guys yall were a huge help getting me started!
Glad you were able to get it done, X2 on Gibson being a good product, I've been really happy with the systems I've had. It's a shame you had to go at the old exhaust with a hacksaw, I did mine with a cordless sawzall, it was cut in about a minute and out from under the truck in about 5!
I also added duals out the back, I had a shop do mine, Me I wasn't completly happy with the the way the driver side looked, instead of it being straight back it veered of to the side a little, so I had the shop make me a new pipe, all and all cost out the door was $ 110.00, IT SOUNDS GREAT, I also left the flex pipe in,,,
Discussion Starter #13
Ya i was thinkin about leaving the flex pipe in but i took it out and now im thinkin it would have been a good idea cause the frame and the suspension will be moving offroad and i think it might do a number on a fixed position exhaust
how much was the exhaust in total? And do they ship up north? haha
Discussion Starter #15
ive heard guys say they got it for like $200-400 from a different website but i didnt wanna bother with different dealers cause my brother got screwed from a different company one time when buying some thing else. so i just bought mine straight from Gibsons website. It depends on which one you wanna get. i got stainless steal which was a little bit more pricier but all in all it was like $650 with shipping of $25. Im sure they can ship it any where i didnt see any red lettering on which states they could and couldnt. so ya they can probly ship it wherever
I paid $ 349 shipped non stainless,,, + around another $100 or so ,,, really sounds greak I all bought the Diablo, and had Diablew do a custom tune,I'm really running sweet,,, with some nice shifts
1 - 16 of 16 Posts
