1 - 12 of 12 Posts
Does anyone use the built-in Oil Life Monitor in their modern GM engine?
Also, who's using regular oil, synthetic or a blend? I'm thinking of moving to a 50/50% regular/synthetic blend and then maybe moving to 100% synthetic.
stevio,why go 50 50 why not go 100 percent,are you worried abut leakage,,if it will by pass gaskets,it will do it at 50 50 as well ,,so try it and see ,,,,i use mobil 1 ,,,abuelito
I personally follow it.
The monitors are calibrated for Regular oil.
I use synthetics and since they last longer I figure using the OLM is an even better bet.
I usually change it at about 10% and thats about 7000 miles worth of driving for me, I'm on the freeway 90% of the time so 7000 miles makes sense.
Discussion Starter · #4 ·
I'm pretty much convinced I need to move to synthetics straight across from now on.
Quote from GM
The GM solution is for motorists to depend on its patented Oil Life System (OLS). The owner's manuals in today's GM fleet no longer make specific mileage recommendations. Instead, the GM Oil Life System analyzes the engine's operational data including but not limited to temperature, revolutions, speed, to calculate the rate of engine oil degradation and determine when an oil is nearing the end of its life. At this point a message on the dashboard signals that it is time to change oil.
Each OLS computer model is engine-specific because GM believes each engine behaves differently under the various driving situations and conditions. For this reason ]GM is on record as stating there can be no standard oil change interval. Both cars and driving styles vary. The OLS allegedly calculates all factors pertaining to the engine and the driver and thereby makes its oil change recommendations.
GM senior project engineer Robert Stockwell has been studying analyzed oil samples from vehicles with OLS.
I wouldn't bother with a 50/50 blend. I went straight to 100% synthetic after i bought it at about 20k miles with 5k mile oil change increments.
I've read that the only time one shouldn't switch to synthetic is if their engine is an high mileage engine or if it didn't have good oil change intervals. The detergents in the synthetic can knock loose the sludge and crap that's built up and clog the oil passages. Then your stuck with a giant paper weight.
Edit: Oh, and i haven't payed attention to the OLM much. Maybe i will now.
I am not using that supposed oil life moniter. I don't believe it works. I use mobil 1 full syn. extended life and the computer is still taking the same amount of time to decline the percentage if that makes any sense. Any ways I bought the truck with 8 miles on it and now have 6000. I have used full syn. for years and love it. I drive about 7k before changing. I know that mobil says 15k but thats ok I will pay more and change it more.
when i first got my truck i was told that the oil life monitor is very percise and even had a built in margin for error .. after a few oil changes i accidently hit the reset button betwen changes and it returned to 100% leading me to believe that it was based on time therefor i no longer use it, nor would i recomend it..
I am using Royal Purple (syn.) and using the OLM. As I have not really seen any real positives to using R.P., I will probably go back to Mobile 1 at the next oil change. Royal Purple is considerably higher than Mobil 1, but I figured I would give it a try. Bottom line, it is hard to beat Mobil 1.
I'm in the same boat right now. I put in Royal Purple because I heard it was really good. Then, I learn Mobil 1 would be just as good for my application, and it sure is less expensive! Oh well...live and learn!
I don't really look at the OLM that much. I peek at it every now and then just to see what it says. I plan on running 6K on this oil change (putting on a new filter at 3K due to a tip I got that Fram filters suck) then switching to Mobil 1. After that switch, I'll probably run about 7K or so between changes.
Mobil 1 15w50 extended interval oil in My '04 Suburban. I don't do 5w or 10w oils, as I feel they become piss water in the crankcase. Of course, I live in a hot tropical southern climate, where it's seldom below 70 degrees, and I frequently pull a trailer.
If I resided in a cooler climate, I'd prolly use 10w30 or 10w40 Mobil 1.
To keep this on topic, no, I don't use the the oil life monitor, and it's something I can live without. I prefer to pull the dipstick, and actually examine the oil on regular intervals, rather than trust electronics. :glasses:
I use Mobil 1 myself. But I still use the oil life monitor still. I have found that it has changed its self to allow for the longer oil change times. Seems bang on to me.
1 - 12 of 12 Posts
