Look in the glove box for the option sheet.
It should have a lot of numbers.
They are all the options installed in your truck at the factory.
I have the 188 page list, ya it’s that long. But I believe Patrick has a link to the list.
That will tell you what you had in the truck when it was built.
I forget what the numbers are for the rear axels.
001 to 009 are axel ratios
OptCode OptCont Opt OptFamOpt OptNounName OptDesc ActionDat OpRe OwActivityStatus
001 34660 P RAT M RATIO 3.70 910409 E T T A
002 34661 P RAT M RATIO 4.11 (4 1/9) 910409 E T T A
003 34662 P RAT M RATIO 4.33 910409 E T T A
004 34663 P RAT M RATIO 4.78 940623 E T T A
005 34664 P RAT M RATIO 4.56 (4 5/9) 910409 E T T A
006 34665 P RAT M RATIO 4.63 (4 5/8) 960806 E T E A
007 34666 P RAT M RATIO 3.07 970827 E T E A
008 34667 P RAT M RATIO 4.88 960806 E T E A
009 34668 P RAT M RATIO 5.29 910409 E T T A
00L 34644 P CCL R SECONDARY COLOR EXTERIOR, PRIME 890523 E T E A
00U 34653 P CCU M PRIMARY COLOR EXTERIOR, PRIME 890523 E T E A
010 34695 P RAT M RATIO 5.43 910409 E T T A
011 34696 P RAT M RATIO 5.57 (5 4/7) 910409 E T T A
012 34697 P RAT M RATIO 5.83 910409 E T T A
013 34698 P RAT M RATIO 3.73 950213 E T E A
014 34699 P RAT M RATIO 6.14 (6 1/7) 910409 E T T A
015 34700 P RAT M RATIO 6.17 910409 E T T A
016 34701 P RAT M RATIO 5.25 910409 E T T A
017 34702 P RAT M RATIO 6.50 910409 E T T A
018 34703 P RAT M RATIO 6.65 890208 E T T A
019 34704 P RAT M RATIO 6.67 891118 E T T A
01A 47354 P STC R STRIPE COLOR ACCENT, TWO TONE, SILVER/GUNMETAL (1995) 980622 E T E A
01L 34680 P CCL R SECONDARY COLOR EXTERIOR, SPECIAL (96) 960118 E 1 E A
01L 49222 P CCL R SECONDARY COLOR EXTERIOR, STARSILVER III, MET2 (OPEL) (2001) 991102 E 0 E A
01U 34689 P CCU M PRIMARY COLOR EXTERIOR, SPECIAL (02) 20419 E 1 E A
020 34731 P RAT M RATIO 5.63 910409 E T T A
021 34732 P RAT M RATIO 6.83 910409 E T T A
022 34733 P RAT M RATIO 7.17 910409 E T T A
02A 47386 P STC R STRIPE COLOR ACCENT, TWO TONE, BEIGE/GARNET (93) 911105 E 1 E A
02I 34713 P CCM M INTERIOR TRIM MED FIRETHORN RED (I) (97) 970522 E E E A
02I 49442 P CCM M INTERIOR TRIM COBALT RED (04) 10820 E 1 E A
02L 34716 P CCL R SECONDARY COLOR EXTERIOR, SPECIAL, CHART NOT REQUIRED 890406 E T E A
02L 49158 P CCL R SECONDARY COLOR EXTERIOR, FIFTIES GREEN (OPEL) 00 990524 E 0 E A
02U 34725 P CCU M PRIMARY COLOR EXTERIOR, SPECIAL, CHART NOT REQUIRED 890406 E T E A
032 34769 P RAT M RATIO 6.29 910409 E T T A
034 34771 P RAT M RATIO 3.54 950719 E T T A
035 34772 P RAT M RATIO 3.38 950719 E T T A
036 34773 P RAT M RATIO 4.44 950719 E T T A
037 34774 C RAT M RATIO 9.77 950807 E T T A
038 34775 P RAT M RATIO 6.57 910409 E T T A
039 34776 P RAT M RATIO 3.55 910409 E T T A
03A 47356 P STC R STRIPE COLOR ACCENT, TWO TONE, WHITE/DK ROYAL BLUE (94) 920511 E 1 E A
03L 34752 P CCL R SECONDARY COLOR EXTERIOR, MARBLEHEAD GRAY MET (96) 960118 E 4 E A
03L 49152 P CCL R SECONDARY COLOR EXTERIOR, CORN YELLOW (00) (OPEL) 990524 E 0 E A
03Q 34757 P MCI R MOLDING COLOR MARBLEHEAD GRAY MET (95) 971103 E 1 E A
03T 34760 P VRC R TOP COLOR MARBLEHEAD GRAY MET (95) 971103 E 1 E A
03U 34761 P CCU M PRIMARY COLOR EXTERIOR, MARBLEHEAD GRAY MET (02) 20419 E 1 E A
041 34804 C RAT M RATIO 7.39 920218 E T T A
045 34808 P RAT M RATIO 5.91 910413 E T T A
049 34812 P RAT M RATIO 5.11 950615 E T T A
04A 34777 P STC R STRIPE COLOR ACCENT, TWO TONE, RED/DK ROYAL BLUE (94) 920511 E 1 E A
04F 34782 P FMT R COVERING COLOR FLOOR MAT, CAPPUCCINO CREAM (F) (95) 921030 E 6 E A
04L 34788 P CCL R SECONDARY COLOR EXTERIOR, BRIGHT WHITE DIAMOND MET (96) 930415 E 4 E A
04L 49153 P CCL R SECONDARY COLOR EXTERIOR, BREEZE BLUE, MET 2 (00) (OPEL) 990524 E 0 E A
051 34840 P RAT M RATIO 6.43 950109 E T E A
052 34841 P TRM M TRIM COMBINATION LEATHER, SHALE (2) (95) 921030 E 6 E A
053 34842 P RAT M RATIO 3.58 10510 E T E A
056 34845 P RAT M RATIO 3.23 950921 E T E A
057 34846 P RAT M RATIO 3.36 910409 E T T A
058 34847 P RAT M RATIO 5.13 941117 E T E A
059 34848 P RAT M RATIO 5.14 910409 E T T A
05A 47323 P STC R STRIPE COLOR ACCENT, TWO TONE, RED/LT BLUE (94) 920511 E 1 E A
05B 34814 P TRM M TRIM COMBINATION CLOTH, SHALE (B) (95) 921030 E 6 E A
05F 34818 P FMT R COVERING COLOR FLOOR MAT, SHALE (F) (95) 921030 E 6 E A
05I 34821 P CCM M INTERIOR TRIM SHALE (I) (95) 980622 E 6 E A
05I 49436 P CCM M INTERIOR TRIM SHALE/MED DK CASHMERE (I) (04) 10806 E 6 E A
05L 34824 P CCL R SECONDARY COLOR EXTERIOR, CYCLAMEN (95) 920811 E 1 E A
05L 48871 P CCL R SECONDARY COLOR EXTERIOR, AZTEC GOLD, MET, OPEL (99) 980622 E 0 E A
05P 34828 P WHC R WHEEL COLOR ARGENT (91) 890306 E T E A
05Q 34829 P MCI R MOLDING COLOR CYCLAMEN (95) 930507 E 1 E A
066 34881 P RAT M RATIO 4.10 (4 1/10) 910409 E T T A
069 34884 P RAT M RATIO 3.90 910409 E T T A
06A 47507 P STC R STRIPE COLOR ACCENT, TWO TONE, DK ROYAL BLUE/RED (94) 920623 E 1 E A
06I 34857 P CCM M INTERIOR TRIM MEDICI RED (I) (97) 980622 E 6 E A
06L 34860 P CCL R SECONDARY COLOR EXTERIOR, SILVERSTONE MET (95) 930312 E E E A
06L 48294 P CCL R SECONDARY COLOR EXTERIOR, LT MEDICI RED MET (97) 970425 E E E A
06L 49154 P CCL R SECONDARY COLOR EXTERIOR, SPACE GREEN, MET 2 (00) (OPEL) 990524 E 0 E A
06U 49497 P CCU M PRIMARY COLOR EXTERIOR, MARY KAY PEARL III (04) 20418 E E E A
070 34911 P RAT M RATIO 5.38 (5 3/8) 910409 E T T A
071 34912 P RAT M RATIO 3.91 941219 E T E A
073 34914 P RAT M RATIO 5.04 910409 E T T A
075 34916 P RAT M RATIO 5.86 (5 6/7) 891127 E T T A
07A 47324 P STC R STRIPE COLOR ACCENT, TWO TONE, DK ROYAL BLUE/LT BLUE (95) 970505 E 1 E A
07L 34896 P CCL R SECONDARY COLOR EXTERIOR, APPLE GREEN (95) 920811 E 1 E A
07L 48757 P CCL R SECONDARY COLOR EXTERIOR, MARY KAY PINK (99) 970108 E 4 E A
07L 49083 P CCL R SECONDARY COLOR EXTERIOR, CARBON BLACK, BERTONE (00) 981120 E 0 E A
086 34953 P RAT M RATIO 9.08 910409 E T T A
08A 47388 P STC R STRIPE COLOR ACCENT, TWO TONE, DK ROYAL BLUE/WHITE (94) 920623 E 1 E A
08L 34932 P CCL R SECONDARY COLOR EXTERIOR, MARY KAY PINK (96) 960118 E E E A
08L 48999 P CCL R SECONDARY COLOR EXTERIOR, URAL MOUNTAIN, MICA (00) (OPEL) 980805 E 0 E A
08U 34941 P CCU M PRIMARY COLOR EXTERIOR, MARY KAY PINK (02) 20419 E 3 E A
090 34983 P RAT M RATIO 3.08 991116 E T E A
092 34985 P RAT M RATIO 4.30 910409 E T T A
09A 46951 P STC R STRIPE COLOR ACCENT, TWO TONE, WHITE/DK SAPPHIRE (91) 891025 E 1 E A
09L 48268 P CCL R SECONDARY COLOR EXTERIOR, CRIMSON KING (97) 940414 E 4 E A
09L 48759 P CCL R SECONDARY COLOR EXTERIOR, MARY KAY PEARL (99) 970108 E 4 E A
09L 48998 P CCL R SECONDARY COLOR EXTERIOR, METEOR GRAY, MICA (00) (OPEL) 980805 E 0 E A
09U 48267 P CCU M PRIMARY COLOR EXTERIOR, CRIMSON KING (02) 20419 E 4 E A
Page 1
And that’s just the first page.
