1 - 4 of 4 Posts
I need an easy way to replace a broken plastic roller that slides in the slot of scissor lift of rear window.What do I need to do? Thanks
No real "easy" way. You have to remove the mechanism, drill out the old roller, and install a new one. Then do everything in reverse. Not hard just time consuming. LMC has an exploded view that is helpful when tearing it down.
1 - 4 of 4 Posts
