1 - 6 of 6 Posts
My daughter and I are wanting to invest in a truck we can go play in. Looking for some recommendations on a good, not to expensive, Chevy 4x4. Just basically looking for a toy that we can ruff house in the mud with and isn't going to cost me an arm and a leg when I do break something.
1973 to 1987 Chevy short or long bed 4x4.
Pros:
Old enought to still be purchased cheap if you hunt around.
large fender openings that could acomodate 33" tires without lifting.
An old truck, want bigger tires real cheap? Just hack t open the fenders more, keeps the CG low but allows up to 40" tires with enough hacking.
Wanna keep the fenders in one piece but go larger? Spring lifts are much cheaper than any IFS lift.
84 to 87 had some of the toughest t cases and axles around. Earlier trucks had SM465 gear boxs, slow on the highway but hard to kill off road.
Small block chevy 350, need I add that its the most popular engine in the world!! Straight 6 engines may lack speed but with their tall deck they have the grunt power to spin big tires real well when geared right.
I could go on and on with this list.
Cons:
They are prone to corrosion above the wheel wells and in the cab corners.
Frame cracks around the steering mounts are popular if you bolt on bigger tires, there are kits available to fix this.
As with any old truck steering assemblies get worn and need rebuilding, rubber was predominantly used in bushings at the time of their mfgr, poly is now available and tightens the steering and suspension real well.
X2 on what tbplus10 said
I like the late 90s model 2500hd's.... my son is still driving mine and parts are cheap.
- - - Updated - - -
Pretty much agree with everyone - 70's, early 80's. Personal recomendation would be a 3/4 ton to start with. most of them have the "big" 14 bolt rear end - near impossible to break and after market lockers are available and not too expensive + most of those already have 4;10 gears. We have a '79 GMC on the place that has 4:56's ! Also most 3/4 tons will have that tough SM465 manual and I believe the auto's would be the TH400 . Not positive about the auto however. Don't worry too much about some fender rust, almost all of them have it. Besides, like tbplus10 said, a sawsall and a four pound beater can be used to fit some big mud tires !! And a large pair of channel lock pliers helps too - done that !
Anything older than 87. Comes with a solid front axle and leaf springs up front. Lifting is super cheaper and down here they can be found anywhere in any condition you want. I'm building and 87 k30 into a Rockwell axled bogger. Easy to do compared to new trucks
1 - 6 of 6 Posts
