97 Chevy Suburban 1500 4wd just started grinding noise under hard acceleration or under load from underneath. Maybe transfer case or transmission area?
If I let up on the gas it stops immediately. Once I'm driving it sounds perfectly normal. Transmission operates normal. Shifting transfer case to and from 4wd is normal.
This one really has me baffled as driving down the road it seems normal. I only get the noise with a hard acceleration. Sounds like gears slipping or grinding.
Checked all the u-joints which I greased a couple days ago and they're all tight. Output shaft seems tight at the driveshaft. No leaks except the transfer case is dripping some oil slowly, but hard to tell from where as it's coming from above.
Swerving on the road seems to eliminate any wheel bearings as I can't reproduce it that way.
It almost sounds like gears grinding momentarily and when I let up it goes away. And I checked with the AC off, so it's not that.
This all just started at the end of a 800 mile drive yesterday.
I'm in upstate NY for my sons college graduation and I hope we don't get stuck far from home!
Any help or ideas would be greatly appreciated!!!
