1 - 2 of 2 Posts
yellow wire hot when applyed joins 3 other wires 1 to back of relay box on fire wall under dash witch is grounded ? 1 goes up under dash cruze mabey? it is also grounded? 1 goes to a small 3 wire plug with white &purple is not grounded soI got a dead short when applyed ???!!!
Jimmy, give us some vehicle info
Also, describe the problem your having
Note, just because you see a ground reading does not mean you have a short to ground, resistive and inductive loads will read a ground potential.
1 - 2 of 2 Posts
