1 - 10 of 10 Posts
either warm or cold there is no change, its shift very hard sometimes barking the 34inch tires from 1rst to 2nd gear. is this normal and i just have to live with it or is there a way to calm that shift point down without effecting anything else?
Discussion Starter #3
very helpful. thank you. ill look into getting the required parts.
BE sure to let us know how it turns out since we havent really had anyone comment about it after a new valve body.. So we are all wondering a bit!
Discussion Starter #5
almost forgot about this thread. i did change the valve body with little difference. i think something might have happened when i had it rebuilt. so in the end it still shifts very harshly. its sometimes cool though. with 34inch tires if i get on the gas it will bark the tires when shifting. and yes this has caused me to have to change out the u-joints already.
ive read somewhere that some tranny rebuild shops change diaphrams to a different type that will have a harsher shift yet not drag the shifts that would wear out a tranny. i have a shift controller in my truck that will make the tranny do the same thing. actually check your harness that goes to the tranny and see if resistors were installed on the solenoid lines. if so it would basically be what i have only the poor mans shift kit. and if thats the 600hp handling 4l60 in your suburban. better believe shes gonna shift like a sculded ape:lol:
Discussion Starter #7
oh it is built 600hp tough. they made me pay dearly for it to. i could have gotten a new stock engine and tranny for what this rebuild cost.
as for the resisters, i removed the tranny and took it into them for the rebuild so there was no chance of anything on my suburban being modified.
1 thing is for sure, it runs nice and smooth when im hauling something. i haul my t-bird to most events keeping the miles off of the t-bird. when its in tow the shift points are almost perfect. that goes the same for hauling left over t-birds after i get done raping them for all of there good usable parts to support my 1 good t-bird. last load out was 5700lbs plus about 1200lbs for the trailer. running down the interstate at 69.5mph in od(4th gear) with no problems.
Discussion Starter #9
nope. no codes to be found either other than for my abs. i disconnected the abs sensors so now that dang light stays on. it wont burn out after over a year so i think im going to have to remove it lol.
I've been living with this annoying problem for 3 years. Changed spark plugs about 2 years ago and it actually stopped for a while. I'm thinking coincidence but I thought it was funny.
I've changed transmission fluid which also helped a bit for about 2 months, then back to the hard shifting. Usually if I step on the gas it shifts smoothly, and like you mentioned when towing it shifts beautifully. I towed a 4000lbs boat 2000km (yes 2000) and never had a hard shift. However I do still experience it with Tow/Haul mode on and no actual load, so I think the weight of towing something helps somehow.
I've been just waiting for my tranny to eventually give up the ghost and have it rebuilt and have been putting money aside into a "transmission fund" so that I can afford it when the time comes. Pain in the @$$ but I'm not willing to pay for some transmission "expert" to poke around and not solve the problem. I'll just deal with it until it goes kaput and rebuild it with better parts.
1 - 10 of 10 Posts
