21 - 21 of 21 Posts
many remove the heater hoses on the heater core fire wall...then the hose fittings crack and leak ..I remove the heater hoses on the engine block .. then use the 5 gallon bucket and then use a water hose spray gun to flush out both directions . now when you did this flush on the heater core probably 12 months later the heater core will drop the higher temps.engine block has particles then the heater core is a filter .
my heater air temp is 140-145 F in 30 deg f outside air ..my 2000 silverado has air filters and I keep them clean every year or change them ..
21 - 21 of 21 Posts
