Hi every body again, i have two questions>
the first one is anybody know how i can check the system than change cold to hot temperature inside cabin. When my truck is tempered, the air inside cabin always remain cold, with 3 speeds on the control panel. i cleaned all of engine hoses relationed with climate system.
The second one is about how i can check the correct functionaling of the fuel pump. i know the pressure control valve near to pcv valve but i don't know the correct pressure or if there is another way to check the pump.
Thank you every body
"visit atacam desert"
