1 - 7 of 7 Posts
Hi, I am kinda new here. I researched (as well as I could) my question prior to posting. I have a 2003 Tahoe that has 80,000 miles. When I turn, either direction, and go over a bump, like backing out of my driveway and turning, there is a clunk from the front end. It sounds like it is on the driver side. I have taken it to my Chevy dealership 3 times and every time, the mechanic (suspension expert) says nothing is loose or not any worn bushings. Anyone else have this problem.
Thanks
Hello.
Any problems when driving, any play in the wheel or shimmy or vibration when going down the road?
I just found this thread...my 2003 is doing the same thing. When I turn to the left I hear a pop in the front left. Mine is a 2wd. No play in the wheel or anything....tight steering. Any thoughts? Not trying t hijack this thread, the last post was in 2006.
I actually worked on a car once that had a similar problem. Turned out to be the black plastic cover that mounts inside the wheel well. Under certain conditions, bumps, or turns the plastic would stick out far enough to bind on a portion of the suspension, and then pop back into place.
Made this horrible sounding bang from the driver's side. Trimmed the plastic cover back, and the noise went away.
If it is that, then it's going to be hard to find, since the vehicle is usually in motion when it happens, and you obviously can't run along side watching it.
See if you can get a helper to stand near by, and watch, and listen for the noise as you drive by.
1 - 7 of 7 Posts
