I got a 2011 Silverado 1500 crew cab 4X4 Z71 everything.
my daughter and wife wanted a step so I decided to have one put on and also got a BDS level kit installed at the same time. This morning I noticed a grinding noise from the front, so I called the guy that put the kit on and he said they don't really mess with anything that would cause grinding when installing a level kit and I should check the tires. I checked them they seemed OK, i went and washed the truck and the grinding noise stopped so I assume he was correct and maybe a rock or peice of concrete got stuck in the treads.
Now the problem I have is when driving or stopping a very low speeds...like parking lot speed the truck creaks, kind of sound like walking on a wooden floor with loose nails. Sounds like something needs lube or a shot of WD40. Has anyone ever had that problem and any suggestions on what I might do to fix it
Thanks
Michael
:happy:
Thanks
Michael
:happy:
