1 - 15 of 15 Posts
Hi. Purchased a 2019 XL 5.3. It’s got about 50k miles. Last weekend I changed all the fluids. Drove it today and when idling the oil pressure dropped to a hair below 30. Normal? I’ve never had a vehicle drop like that when idling. Also when idling every 10 seconds or so I feel a very light movement. Normal? Everything sounds fine and drives good. Not sure what to make of this. Any information helps. Exactly 8 quarts added during the oil change. Thank you.
30 at idle is fine. As for the other thing, do you notice the tachometer moving when it happens?
20 at idle meets GM spec.
I suspect what you feel is the computer disabling cylinders, it's called DFM
Discussion Starter · #4 ·
Thank you Greg and Rey for the response. I appreciate it. Took a drive today to monitor the gauges. Idles at 30. Normal cruising sits at about 40. Will let it be and not think much of it.
As for the slight movement I feel every 7 ish seconds when sitting idle. The tachometer does not fluctuate. Maybe just a normal mechanical function/movement?
The engine will idle at the same speed, just some of the cylinders will be de-activating.
Your right, the 2012 5.3 (gen 4) needs 6 qts; however, the 2019 (gen 5) needs 8 qts.
Yep, more oil but it's making more power at 355hp and 383 ft-lbs torque on a 5.3L.
My 2001 only has 285hp I think.
The 2018 tows better but not sure how tough is the 6 speed tranny.
I seems to be plenty tough, my 6 speed has towed a bit; but my buddy uses his a lot, pulling a 36 ft car hauler.
I hope so Ray.
You know, there is no direct 1:1 drive on the 6 speed 6L80.
4th gear is almost a direct at 1.152.
5th gear is an overdrive at 0.852
6th gear is at 0.667.
If you tow in tow/haul mode, most of the time it's going to be in 5th and 4th on inclines and 6th on downhills.
I hope the 4-5-6 driving clutches are strong enough to last as long as my 4L60e now at 288k miles.
But we will see.
I tow a 5k pound camper.
The car hauler 3 of us take turns hauling is around 5500.
I use the manual shift and keep it in 4 most of the time; but my buddy with the 1500 just uses D and let's the computer pick the gear. The 2 trucks both have 5.3s and the 6 speed. The 3rd truck is a 2500 with the 6.0 and the 6 speed; but it may be the 6L90.
Yes, I used to tow in L5 back when I didn't have a Range AFM disabler.
With the Range AFM disabler, it's now always in V8 so I just put it in D and engage the tow/haul mode.
Good to know.
How many miles now on the 5.3L?
Sorry for hijacking the thread OP.
I've got about 160 on my 5.3, I don't know what's on the other one.
1 - 15 of 15 Posts
