Who has used this product is it worth it? How far will one kit get you? Enough for a full size short box?
I used the small can (1 qt) to touch up my old trucks rhino liner, and add over the rails. I was very unimpressed, in less than a year the color had gone away and I just had speckled grit on my bed rails. I did it right too, sanded everything down, wiped down with acetone. Maybe others have had better results?
I had good results with Herculiner on my 2013. I did one coat, let it dry, did another coat, then a week or two later, did another coat. Held up well from drums of oil, pallets of material being slid in and out, wood and metal fenceposts, etc. Didn't fade all that much, but then, the pickup was garaged when not in use.
Now, that being said, my 2015 got Line-X. Mostly due to convenience (busy schedule) and being very cold out that is was impractical to do the Herculiner thing this time. Just bought the 2015. Line-X looks neater, but will see if it does much better.
From a looks standpoint, the Line-X would make someone fee better.
I used to own a 2001 Dodge Dakota that has been sitting in another guy's back yard since 2008. I had Line-X sprayed in the bed in 2002. All the paint is gone off the horizontal surfaces of the truck, and as of right now, the line-X liner looks just like it did when it was sprayed in 12 years ago. The liner had power tools, and refrigerators and the like slid all over it for 6 years, occasionally raising a light gray scratch or two which would disappear in a few days.
