Brake wear
When I hit 50000 miles I had my brakes checked (original equip) and was told that the brakes had another 10000 to 20000 miles left but I should plan on replacing the rotors since they probably would not be able to be turned due to wear. At 70000 I noticed some pulsating and took it to another facility and was told that the front rotors were warped and the rear were too thin to turn and everything needs to be replaced. I was wondering if anyone else has had to replace their rotors? In the past with other vehices I normally just replace the pads. The rotors usually don't go until well past 100,000. The dealer said that GM is using some aggressive metal brake pads and the rotors are just wearing down sooner, which is basically the same thing I'm hearing from other repair companies. So, I am curious if this is an ongoing problem.
