1 - 12 of 12 Posts
Have you purchased a brake controller yet? If not, there are a few out there that are easier to install than others. I installed a Prodigy controller in my Silverado that was just plug and play because you can get a wiring harness made for your application. Just plug one end into the back of the controller and the other end to the trailer wiring panel that's usually on the drivers side floor up in the corner to the left of the brake pedal. GM usually provides a harness with vehicles that have a tow package but you still have to splice the wires to another plug or wires coming out of some brake controllers.
Super Moderator
It isn't terribly difficult, I did my own with the help of my grandfather. The hardest part was to try to figure out why I was blowing the turn signal/backup fuse. Then I fealized that I had accidentally grounded the backup lights line to ground. My Suburban has a 4-way flat connector at the back of the truck next to the hitch up at the floorpan. It's your normal 3 connections plus the reverse signal lights where the ground typically is. I plugged my 4 to 7 way converter directly into that connector without thinking twice... Other than that, it was relativley straightforward with running the brake and power lines to the back, tapping into the brake switch line...
I need to transfer my prodigy from my Titan to my 2008 Burb 2500. What harness do I need from Prodigy?
3015 - (2003-Current) GM Brake Control Wiring Harness
3015-P - (2003-Current) GM Brake Control Wiring Harness (Clam Shell)
I don't know what the difference is with the above...Anyone help?
not sure on 2008 yet havent looked but if it is like 2007 models there is no plug you have to hard wire it
here is the directions (unavailable)
http://www.stealthv.com/images/GMT900_Trailer_Brake_Controller_Install.pdf
(unavailable)
WOW! That's rather complicated. Mine was the easiest I have done. I have one hardwired in my 87 Blazer and used the factory pigtail for my 2001 Suburban, but the prodigy was the easiest with it being "plug and play".
Thanks!
Instructions worked great! Put my laptop in the garage and finished everything in under2 hours! Better than paying a garage the $150 they wanted!
Thanks for the instructions!
(unavailable)
Thanks so much
I registered just to thank you so much for the instructions on installing a brake control on a 2008 suburban.
I would not have been able to complete the installation with out the information you made available.
I still can't believe it. Pictures and instructions that were perfect. Thanks
1 - 12 of 12 Posts
