1 - 19 of 19 Posts
I have a 97 k1500 Suburban with a 5.7L vortec OBDII.
How can I adjust the timming? I know it's with the distributor. But do I need to put the computer in diag mode or something so it doesn't compensate for my adjustments?
Thanks in advance!
Eric
· Super Moderator
As I understand it, you have to have a scanner that will read the "cam position sensor retard" parameter. I also understand that not many scanners can read this parameter. From what I understand, once you can read this parameter, it's a simple matter of rotating the distributor until this parameter is +/- 2 degrees or something like that.
shiat... OBDII can be so sweet and yet so complicated...
I think I have my timming too far advanced... I think I have a ping problem, but not 100% sure what that sounds like.. Sounds a little like a squeeking alternator bearing but oly under load.
· Super Moderator
The best description I've seen for pinging is a dull "marbles rolling around in a can" kind of noise.
Discussion Starter · #6 ·
What does the trucck do? is it missing idling rough etc. honestly i dont thing you have a pinging problem because the computer would retard timing to eliminate it.
It idles rough when cold. New temp sensor was installed so that's not the prob. I'm due for a tuneup.
I canhardly describ the sound... It's a squeeky ticking sound. Sorta like your dash vibrating and rubbing against some trim. I thought it was my alternator or waterpump starting to go. But it only happens under load (acceleration) not when I rev the engine in neutral.
There is NO loss of power when the sound is there.
I do have a constant high idle problem... sets off code 507...
My knock sensor looks old and rusted. I may replace that.
I'm starting to suspect EGR...
Really the only thing that could shed some deffinite lite on the problem is a coomputer diagnostic. But I can't find a tech locally that will diagnose the truck with a TECH-II and let me see the readings. All they do is use the readings for their own diagnostic to solve a problem. I would like to know all that the computer sees...
Thanks for your help and I welcome any advice!
Cheers!
Eric
fierodough, check out http://winaldl.joby.se/ for ECM scan tool that is free. It connects to your pc.
"WinALDL is a program that reads the ALDL data from some supported ECM types. The data is presented in a way that will help when tuning a car after engine modifications. A simple hardware interface must be built to convert the ALDL data stream and make it compatible with a PC serial port
The original idea for this program came from Ken Kelly. At first we just wanted to write a good free scanner for the 1227747 ECM. Then We added another one ... and another ...
I have used information found on the internet when writhing this software. I don't have access to the ECM's supported, so I can not test everything. Please let me know if you find something wrong and I will try to fix it. If you have a 160 baud ECM that is not supported you can still use the raw data logging. I might be able to add support for more ECM's, but I need information about the 160 baud data stream for that ECM."
Nice find on the internet, Thanks unplugged I always wondered about that.
Siskel and Ebert give it two thumbs up :great::great:
Good find, but I'm pretty sure WinALDL only works on OBD I, and was not programmed to work with OBD II, which the '97 will have.:frown:
I haven't looked into this yet...but did you just brust my bubble. I was looking forward to checking this out tonight.
Not necessarily. I'm going to look around a little, I know there are software options out there for OBD II, but I don't think that's one of them. I'll post back here if I can find it. But Uplugged is on the right track. There are a few good alternatives like this compared to going out and buying a $300 and up system.
Discussion Starter · #12 ·
There is software for OBD-II but building the hardware can be tricky. The port connector is propriatary and the components get a little more sofisticated.
· Moderator
I bought an ODBII reader on EBay for 130 Euro it’s a Geniscan GS400
It does its thing and you also have freeze frame data with fuel trims and other data.
If you do the maintenance yourself you can’t live without it. :present:
Discussion Starter · #18 ·
Thats a cool idea, but your climbing close to OBDII reader costs. Oh decisions...decisions! :neutral:
BTW eric did you check out NEW section "Regional- Canada"...we are taking over :he:
It's a simple decision. Go with the computer attachement. Scan tools are expensive to upgrade. PC software is very competitive. And from what I can see, the pc version has alot of extra features! Like the virtual dashboard.
What I am researching is what device allows write back to the ECM. To make adjustments ect..
PS: Cableguy, click my sig and join the Cable Patrol group. ;)
1 - 19 of 19 Posts
