1 - 2 of 2 Posts
ok here is the situation, i have a 93 suburban k1500. one morning i was driving it to work and i hit the gas pedal to pass someone and the engine died. i then coasted off the road and tried to start it agian it had juice when i turned the key to run position but when i turned it to start it it went dead. later that day i towed it home started to look around to see if i could find whats wrong. finally i figured it out. it seized up. i tried a bunch of stuff, taking out the spark plugs, wd40 in the hole there, manually turning it from the harmonic balancer then from the fly wheel. i finally got a small turn out of it when i used a bottle jack to push up on it. if any body has any ideas whats wrong or what to do please help.
thanks
Can you say e-n-g-i-n-e s-w-a-p? Sounds like something is seriously broke. There wasn't a kaboom before it died?
1 - 2 of 2 Posts
