I have a 02 TB that I tow and it is a PITA to pop the hood and pull, or reinstall, the two fuses each time I connect or disconnect from the motorhome. In searching for an easier way I thought of inserting a switch to the wiring from the ignition switch to the fuse box.
The problem is the time it will take to research and test to find the corect wires. Having a wiring diagram or knowing the color codes for the wire(s) from the ignition switch to the fuse box would help.
Thanks
Thanks
