1 - 2 of 2 Posts
I have an 01 Silverado 5.3l with about 60k on it. Came across a problem the other day with my instrument cluster. When I start the vehicle, the lights that display my gear selection dont light up and my battery light comes on in the display. I also noticed that my engine temp sensor isnt reading. Everything else works fine with the dash and lights on my truck. When i put the key in and turn it once, the gear selection lights up and everything seems fine its only when i turn it again and start. I checked the fuses and none seem to be blown. Any idea as to what this may be?
Any DTC codes? Sounds like a power problem, especially since the 'batt" light is on. Check and clean your battery terminals. There was a recall on the 05 trucks for a shift indicator illumination issue, so you may have a fault in the ECM.
1 - 2 of 2 Posts
