1 - 3 of 3 Posts
After really looking is it possible to put the entire interior of a 2006 Tahoe into a 2000 Silverado 1500
Yes, but things may not be a direct fit. You may have to reuse your Silverado seat brackets, or make some new ones. Also you may need to drill new holes in the floor for seats, console, ECT. As for the door panels, you may need to swap the Tahoe metal base panel ( under the door panel, that holds the glass ECT) with yours. The dash should swap, but the gauge cluster may need to be repined along with the rest of the controls IDK. But size wise, yes the Tahoe interior will fit.
Mostly. As @kennythewelder said, there's some modification you'll need to do. Some because the truck and the SUV vary slightly in body panels. For example, I picked up some '03 Silverado fender flares that claimed they were a direct fit for the Suburban. They were not and in the words of Johnny Cash "So we drilled it out so it would fit..."
1 - 3 of 3 Posts
