Does anyone know where the clips are on the interior front door panels? I need to remove the panels to replace the door latch handles. Yes, both sides broke within a week of eachother.
If your talking those pine tree looking clips there pretty cheap (I have a bag of them on hand when i'm working on that stuff) That track in there seems pretty cheap doesn't it. I've had to replace and relube these before. They certainly are a pain to get in there and work on.Hey, I finally replaced my door handles. Yes, I know I posted the question pretty long ago. I want to thank you all for your help. I did the passenger side first. It took a bit of time discovering pieces of panel/trim and the order in which to remove them, and figuring out the clips, but I got it done without breaking one. The actual handle module was stabilized with a metal rivet. I had to makeshift with a screw in when I put in the replacement. (However, I did lose the bulb in the door courtesy light.) The driver side was a lot easier after that but I broke one clip. I just left one of the bottom ones unclipped. Maybe if it rattles or creaks enough to bother me I'll replace it.
