Status
Not open for further replies.
1 - 9 of 9 Posts
If I jump up and down at work and whine like a little baby do you think fleet might send me a nice Chevrolet Express?
Damn I want a Chev or GMC at work. They ride nice, drive beautiful, if your in the market for a work van I dare you to drive a Dodge or Ford then the Chev. Then honestly tell me its not the best choice. The biggest thing is it has the best MPG on the market for work van.
Do the drivers have any say? I'll write up a proposal for you if you want to present it to your management why you should be behind a GM wheel. :rolleyes:
It sounds like this little back door deal with Ford is falling apart. The guy who's boss is in crap already. MPG went thru the roof and cost of van did too. So hopefully they wake up out of there deep sleep and can his a$$. Sounds like there in neck deep with them though it might take some work to get out of it.
Discussion Starter · #4 ·
2007 Savanna/Express specs.
2007 GMC Savana Performance & Efficiency Standard Features
- 5,328 cc 5.3 liters V 8 front engine with 96 mm bore, 92 mm stroke, 9.5 compression ratio, overhead valve and two valves per cylinder LM7
- Unleaded fuel 87
- Fuel economy EPA highway (mpg): 18 and EPA city (mpg): 14
- Multi-point injection fuel system
- 31 gallon main unleaded fuel tank
- Power: 220 kW , 295 HP SAE @ 5,200 rpm; 335 ft lb , 4,520 Nm @ 4,000 rpm
2007 GMC Savana Handling, Ride & Braking Standard Features
- Four-wheel ABS
- 3.42:1 axle ratio
- Four disc brakes including four ventilated discs
- Electronic brake distribution
- Immobilizer
- Fullsize steel rim under body spare wheel
- Wishbone front suspension independent with stabilizer bar and torsion springs , beam rear suspension rigid with leaf springs
2007 GMC Savana Exterior & Aerodynamics Standard Features
- Black front and rear bumpers
- Day time running lights
- Driver and passenger externally adjustable black door mirrors
- External dimensions: overall length (inches): 224.1, overall width (inches): 79.4, overall height (inches): 81.6, ground clearance (inches): 7.6, wheelbase (inches): 135, front track (inches): 67.8, rear track (inches): 67.8 and curb to curb turning circle (feet): 43.4
- Conventional lens halogen bulb headlights
- Heat reflective glass
- Black paint
- Rear platform step
- Tinted glass on cabin
- Weights: gross vehicle weight rating (lbs) 7,200, curb weight (lbs) 5,179, gross trailer weight braked (lbs) 6,500 and max payload (lbs) 2,021
- Windshield wipers with variable intermittent wipe
2007 GMC Savana Interior Standard Features
- 12v power outlet: front and 2
- Air conditioning
- Fixed mast antenna
- Automatic drive indicator on dashboard
- Cargo area dimensions: length (inches): 127.8, width between arches (inches): 52.7, height (inches): 51.9 and loading floor height (inches): 27.7
- Cargo area light
- Cargo capacity: all seats removed (cu ft): 267.3
- Second passenger side and rear double-hinged cargo doors
- Clock
- Full dashboard console with open storage box
- Delayed/fade courtesy lights
- Front seats cup holders fixed
- Door pockets/bins for driver seat and passenger seat
- Floor covering: plastic/rubber in load area
- Driver and passenger front airbag with multi-stage deployment
- Bucket driver and passenger seat
- Height adjustable 3-point reel front seat belts on driver seat and passenger seat
- Two head restraints on front seats
- Internal dimensions: front headroom (inches): 40.2, front hip room (inches): 65.5, front leg room (inches): 41.3 and front shoulder room (inches): 68.8
- Low fuel level warning
- Power steering
- Vinyl seat upholstery with additional vinyl
- Seating: two seats
- Service interval indicator
- Two speaker(s)
- Plastic steering wheel
- Ventilation system
2 New Ford E250's just came in, I turned them down hoping a Chev might be coming....I told the service guys to take them LOL
It sounds like this little back door deal with F### is falling apart. The guy who's boss is in crap already. MPG went thru the roof and cost of van did too. So hopefully they wake up out of there deep sleep and can his a$$. Sounds like there in neck deep with them though it might take some work to get out of it.
You just forgot to blur out the F word so i did it for you:lol::great:
1 - 9 of 9 Posts
Status
