What you think of my Kenwood install on my '87 Sierra Classic. Its my first install and i did it on my own.
As long as you have a wiring harness for the truck that plugs into the factory connector, it's a simple job of matching wire colors. Now, getting the dash bezel off...that's a major b*tch. Every time I go to pull it off, I cringe and start thinking about whether I REALLY need to get whatever I needed to do done. However, once I figure out how to get the headlight switch off, it became easy, but tedious with all the screws. Good job on the install. That looks cleaner than my install, which install kit did you use?thanks, since it was my first i learned a few things. it isnt as hard as i thought to wire it up but getting the old one out was a PITA
i got everything for the install from crutchfield.com thats the best place to get anything audio/video for a vehicle from. cutting out part of the dash to fit it was the hardest part. thanks for the compliment. lets see a pic of your install cause i bet it aint that badAs long as you have a wiring harness for the truck that plugs into the factory connector, it's a simple job of matching wire colors. Now, getting the dash bezel off...that's a major b*tch. Every time I go to pull it off, I cringe and start thinking about whether I REALLY need to get whatever I needed to do done. However, once I figure out how to get the headlight switch off, it became easy, but tedious with all the screws. Good job on the install. That looks cleaner than my install, which install kit did you use?
