This past fall I finally upgraded from factory size street tires to 33" AT's. I also bought a set of Trailmaster torsion keys, which list up to a 2.5" lift, and got the shop to install them the same days as they did my new tires. They did a great job and afterwards my truck sat perfectly level and looked great paired with my new Toyo ATII's. Unfortunately, I failed to pre-measure my stock front height so after they installed the keys I wasn't sure of exactly how much it had been lifted. Also, of note, the keys came with 2" shock extender mounts which were also installed.
The street ride didn't noticeably change, however, I have noticed in some moderate offroad situations and even on pavement, primarily large speed bumps, that whenever I go over a large bump (such as a speed bump), rut, rock, etc that causes the front end to go up quickly, that it comes down farther and bounces a lot before dampening out. On the speedbumps in our parking lot at work it has actually bottomed out once before when I hit it pretty hard.
So after all of that, my question is if the torsion key advertises a 2.5" lift, but when installed the new keys are only tightened enough to level it out and only ends up lifting it say 1.5", are the torsion bars now too lightly preloaded thus putting more on your shocks than they are designed for? And if the front end was only raised up 1-1.5" should the new shock mounts have not been installed?
I plan on installing an add-a-leaf within the next few weeks and after doing so plan on cranking the torsion bars up more to re-level it out (hopefully utilizing near the full 2.5" Trailmaster advertises) and was hoping in doing so it would get me back closer to the factory ride.
Any insight would be greatly appreciated.
