To be clear, a leveling kit and or cranking of the Tbars will most definately cause premature front end wear. That is an unescapable truth, however when kept to a minimum it's nothing serious. But I disagree that cranking the torsion bars will cause a truck to ride like crap, at least not anymore than "leveling" keys. The problem comes with over cranking. All re-indexed leveling keys do, is allow you to crank your torsion bars more than the factory keys would allow. Thats it. They allow you to overcrank your tbars in most cases. So cranking the factory keys is the way to go, unless your factory keys dont allow for more adjustment, which can sometimes be the case. The bottom line is don't go any higher than about 2" over stock.
