I am looking in to buying a 1988 GMC Subyrban High Sierra. Its got a 350 with newer center bolt valve covers, automatic transmission, its a 4x4 1500 with leaf spring. Everything seems to be really nice for its age, is there anything special I should be on the look out for ?
There seems to be a small leak in the transfer case in the bearing seals for the yokes, its a NP 208 case, is this common ?
The underside is super clean, I know this bodystyle is prone to rust but this one seems to have escaped fairly clean. Are there any hidden areas of rust I should check for ?
Does anyone know which transmission it might have, Its probably a 700R4 since it has overdrive but I'm not sure.
Is there any problems with the fulltime front axle ? I'm used to Fords with the option to open the front hubs so the axle isn't spinning away underneath. And did any of these come with a front locking differential ? With the transfer case engaged I made a tight turn and the front wheels slid and skipped like a locker would.
Any info will be greatly appreciated, I will make the deal sometime this week, thanks.
