1 - 7 of 7 Posts
Started my truck today and had the CEL come on, plug in my DSP to scan the code and it comes back with p0107; Manifold Absolute Pressure/Barometric Pressure Circuit Low Input. Does anyone have a diagram of where the MAP Sensor is located? I want to check if something came loose before I run out and buy a new sensor.
Moderator
Below is a Diagram of the 6.0 liter Intake Manifold.....Number #5 in the diagram is the Map Sensor.....hope this helps you out,
Before you go and replace the MAP sensor, being that it's a circuit fault that means you have a break in the wire going to it. The design leaves it exposed to the high temperatures of the motor, Just inspect the connector and it's wires for any breaks before you replace. There is also a way to check the MAP sensor by reading the voltage off pin a--pin c, it has to be plugged in and the motor running to check it. It's a major PITA, but it's how you troubleshoot one.
Discussion Starter #4
Thanks for the diagram, and I didn't see anything abnormal from the visual inspection, I will have to find something to read the voltage.
could be the MAP in in the rear of the upper intake manifold.. 6L engine .
look up the MAP sensor on a auto part store then the upper intake manifold will show you the exact part.
1 - 7 of 7 Posts
