1 - 3 of 3 Posts
Replacing motor mounts and was wondering if it is ok to raise engine using the bracket where the belt tensioner is. Gonna remove said part for clearance
driver side MM is most part that fails . do not lift the oil pan . exhaust manifold or a bracket use a piece of wood at the lift point so the lift will not slide off. it is a hard part to replace ..probably need a very good rust buster oil and give it a few days to loosen the rust.
Discussion Starter #3
Thanks. Job done used the lift point to the left of the tensioner. Wasn’t too terribly horrible. Kinda limited access to top bolt. Thanks again
1 - 3 of 3 Posts
