1 - 3 of 3 Posts
I posted a few days ago about an issue with my blinkers stopping when brakes are applied after replacing my multifunction switch. I have since realized that both tail lights flash when I turn on either blinker. I believe this must be another indication of the problem. The indicator on the cluster shows that only one side is flashing, but both rear tail lights (not front) are flashing, as if my hazards are on, even though only my blinker is on. When I hit the brakes, I hear a very brief buzz when the lights stop flashing. As soon as I let off the brakes, they resume flashing. Any help is appreciated.
i belive you have a ground issue, you need to check your grounds from dash all the way to back of truck , got thru them and do a wiggle test see if i shows up
Are you sure you have the correct multifunction switch?
1 - 3 of 3 Posts
