1 - 4 of 4 Posts
1965 Chevy C10 Custom
Lowered, Electric Windows, Air, Under Bed Gas Tank, Pioneer Radio/TV/DVD 6 speaker system w/Amp Remember it is work in progress.
383 Stroker Edlebrock top end, Headers, K&N, MSD Ignition/Distributor.
I do have to find a mysterious battery drain that will not make itself know though. Cleans out an Optima full charge in 2 1/2 days.:grrrrrr:
View attachment 28281 View attachment 28280
View attachment 28279 View attachment 28278
Welcome to the club. That is a SWEET truck.
Welcome to the club. Battery drains are fairly easy to find. Unhook the neg batt cable. Hook an ampmeter or a test light between the negative batt post & the cable (don't use a voltmeter) Remove one fuse at a time untill the amprege drops to zero or the light goes out. That will be the circuit that has the draw. Once found & fixed, recheck (for another draw) & if you have another, continue pulling the remaining fuses because on a '65 it could have more than one.
Discussion Starter #4
Thanks Guys
Thanks for the welcome I appreciate that.
I will try pulling fuses It is an after market wiring harness (no glass here) EZ Wiring.
Thanks again will be on here more and more.:happy:
1 - 4 of 4 Posts
