1 - 2 of 2 Posts
i have a 91 silverado 4x4, i replaced the rear drum brakes and now the outside brake lights dont work. Also the interior brake light flashes, 9 flashes and then holds for 1 sec and then repeats. and to top it all off the e brake doesnt wrk . the brakes stop well but i have a 4 hour trip to make tomorrow so i need to get this fixed .
any help is greatly appreciated
did you check the fluid level in the master cylinder? is the brake light flashing or the ABS? if it is the ABS then that is 4 sets of numbers and you can get a code reader for it. if it is brake then most of the time it is the e-brake or fluide level. you got all the parts in the correct spots in the drum? did you adjust the shoes after thr install?....mike
1 - 2 of 2 Posts
